Thread: pressure tanks plastic metal?
    Default pressure tanks plastic metal?
    Are the plastic type pressure tanks better than metal?What is the average life on tanks and are they all in the same ballpark?I have a welltroll wx-202 20 gal that is probably shot its about 8 yrs old.Sears has simer and tractor supply has dri something,grainger has dayton in the catalog,on **** they have a plastic one so does grainger its a dayton too.What would a 35 gal tank do for me compared to a 20?Is it all about pump cycles or does the pressure last longer with a bigger tank? thanks for any info steve.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Quote Originally Posted by kodiak
    The drawdown of a tank is about 30% of the volume of the tank for a pressure switch setting of 30 to 50 psi. Pressure will drop more slowly with a larger tank.
    The drawdown should be at least eaqual to the GPM capacity of the pump for small pump (Maybe up to 1 HP) and 2 minutes for larger pumps. That means that for a small pump the actual volume of the tank should be about 3 times the GPM rating of the pump.
    "Plastic" tanks are usually fiberglass reinforced plastic. The life-limiting element of most tanks is the bladder, although I have seen some painted steel tanks rust out at a weld before the bladder fails. I have never heard of a fiberglass reinforced vessel failing before the bladder fails.
    Previous member
    Jul 2005
    Riverview, Fl.
    I don't care for the bladder in the Fiberglas tanks. They are inferior compared to the two top of the line Manufacturers; Well-X-Trol and Flexcon.
    All the places you mentioned where you are shopping sell the inferior tank brands as they are cheaper. Whether they are metal or plastic.
    bob...
