Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: What's the thing called on a freeze proof hose bibb?
    DIY Senior Member Melissa2007B's Avatar
    Jun 2007
    Denver, CO
    Default What's the thing called on a freeze proof hose bibb?
    We have these hose faucets that are apparently called "freeze proof hose bibbs", from what I've been able to find out on the web so far.
    But when this modular house was built a couple of years ago, it looks like some parts got left out of one of them, and that thing on the top gushes water when you turn the hose on. I checked inside it by unscrewing it and then looked at one of the others, and it's missing some internal part that appears to be like a pressure valve that closes it when you turn the hose on.
    So I took the whole thing with the bad one, in to Home Depot and Ace and got treated like a martian in both stores. They didn't know what the thing is, never saw one before. But I pointed out that they were selling these kinds of faucets with the durn things on them. They still didn't know and said they don't sell them separately.
    So I need to know what these things are and where to get a replacement one. Anyone?
    It's the aniti-sphon on the hosebib.
    The faucet will have a brand name on it.
    You will be able to look them up on the Internet, and they should have replacements parts for it that they can send you.
    It's a very easy repair.
    Jun 2007
    Denver, CO
    Thanks Terry! Actually you can see a brand mark in my photo. SA?
    As Terry points out, that's the anti-syphion part that you're looking at. The frost free valves might look the same on the outside, but they extend 12" through the wall where they connect to the supply line. The actual shut-off part is clear inside so the valve will drain when turned off. That is they will drain unless one leaves the hose hooked up in the winter. Then that 12" pipe will split and you will have a flood the first time you turn the valve on.
    Plumber jimbo's Avatar
    The antisiphon part has nothing to do with the freeze protection, but it is the part which usually leaks. They differ by brand, so parts are not generic. Your marking is SA inside a C. It is the mark of CSA, the Canadian Standards Association. Means it is approved for use in Canada.
    CSA is a government agency, but performs roughly a similar function to the private UL in the lower 48 here. They do have their fingers in more pies than UL.
    Jun 2007
    Denver, CO
    Ok, can anyone tell the brand and model from these photos?
    Nov 2006
    Quote Originally Posted by Melissa2007B
    ... when this modular house was built a couple of years ago ...
    I would try contacting the modular's manufacturer or the dealer that sold and set the unit. Having come from Indonesia, that faucet was likely supplied by a mobile/modular component importer/vendor and might not be found anywhere else ... yet a reputable modular dealer should still be able to offer some kind of help.
    Can you see the plumbing connection at the other end of the faucet? Overall, you might be better off just replacing the entire assembly.
    If it was mine, I'd just replace the whole thing. You might find the part(s) you need easily, but if they are hard to find, you would spend more time and money finding the parts than the thing is worth.
    Jun 2007
    Denver, CO
    Quote Originally Posted by Gary Swart
    I might just put some silicone in it and let it dry, then screw it back on there.
    Jun 2007
    Denver, CO
    Quote Originally Posted by Terry
    Not sure how we could tell Terry.
    I think at this point, just call Merrill on Monday
    US and Iowa:
    800.831.6962
    "Made in Indonesia" pretty much tells the story......that's the end of the story. Look for a new valve.
    The silicone might work for a temporary fix, not much to lose by trying, but I'd still replace the darned thing.
    Jun 2007
    Denver, CO
    Maybe when I get some money, not making enough right now.
    Been wanting to replace all 3 with 1/4 turn faucets though, these require about 10 turns to fully open.
