Results 1 to 3 of 3
Thread: Perforated down spout tubing
    Default Perforated down spout tubing
    I have been landscaping for some time now, and it has come into question as whether to use perforated corrugated tubing or tubing that does not have the perforated holes?
    I am burrying the down spouts for my customer with perf tubes and the irrigation company on site has voiced their concerns on the type of tubing that I am using.
    I have used perf tubes for years with no problems
    Any opionions, either way
    Marc
    DIY Senior Member Mr_Pike's Avatar
    Jun 2007
    Nebraska
    I see it both ways all over.
    There are arguments for both. If you have trouble with water in your basements in the area, then I would personally install the non perforated version. If you have decent drainage, the perforated version won't hold the stagnant water and tends not to clog in that late winter early spring freeze thaw time. Tell the homeowner you will use what he prefers, but explain why you use what you do, and that different contractors use different stuff.
    DIY Member Kiril's Avatar
    Jun 2007
    Sacramento, CA
    Each site is unique. Use the appropriate pipe for the situation.
