Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: Leaking G-Max or Power Gravity Fill Valve.
  1. #31
    Assuming you have the Korky fill valve on your Toto, yes, the Korky replacement cap works and would be my first attempt rather than replacing the whole thing. While the one they make for Toto says Toto on it rather than Korky, they are shaped the same and take the same seal. Once you figure out how, it takes about a minute. While you've got it apart, check the screen and clean it if needed.
  2. #32
    DIY Junior Member feeth's Avatar
    Mar 2012
    GA
    So if my toto looks like this on the inside (tsu25a), see the attached files. I can use what Terry has listed below?
    I bought one of the $2.50 caps from Lowes and it appears they wont work.
    TIA!
    I've used the Korky MaxPerformance valve on the TOTO bowls. It has an adjustable bowl fill that the TOTO needs.
    You can also use the Korky 528T
  3. #33
    Toto uses a couple of different fill valves, and the one you have is not made for them by Korky...sorry. As I understand it, that one is not repairable, and if it leaks, must be replaced. You do want one either made for Toto or one that is adjustable so that you don't waste water and get a good flush. Those made for Toto balance the bowl and tank refill so both just fill when the tank shuts off flow. Otherwise, you'll either end up with dumping excess bowl water down the drain, or not having enough water there so there's a lousy flush. Korky does make a generic adjustable valve that will work with any model and may be quicker to find than the custom one for Toto. That one has a little valve you adjust to balance the flow so both the tank and the bowl fill up at the same time...should only take a couple of minutes longer than a straight replacement to get it right after a couple of test flushes. I think there's a video on their website.
  4. #34
    Mar 2012
    GA
    Thank you Jim! I installed the above pictured korky valve and everything is all well.
  1. Open Toto Power Gravity Fill Valve
    By mj-victoria in forum Toilet Forum discussions
    Last Post: 08-28-2008, 11:36 AM
  2. Toto: Replace Power Gravity valve with G-Max?
    By DonnaM in forum Toilet Forum discussions
    Last Post: 11-13-2006, 01:15 PM
  3. Toto fill valve leaking?
    By rockjet in forum Toilet Forum discussions
    Last Post: 07-03-2006, 04:28 AM
  4. Toto Power Gravity Flush Valve
    By Helper in forum Toilet Forum discussions
    Last Post: 05-20-2006, 04:31 PM
  5. Can I replace a Toto Power Gravity Valve w/a GMAX Valve?
    By IMALIVERU in forum Toilet Forum discussions
    Last Post: 04-03-2006, 04:47 PM
