Goody, new cabinets, counters, and sinks and I'm doing it myself. The old sink went to an abs p trap and then a little more abs pipe into the wall. The whole assembly is made of small sections that are glued together and won't meet the new sink due to different sized everything. I have a really sharp saw and I can cut thru anything but how do I connect the cut end to something new? It's not like cutting a long run of pipe where you join 2 straight sections by sliding each into a connector. Any cut I make will go thru a glued joint. What's the right strategy? Thanks.
