Hello there..I found this forum while in search for help with a shallow well . I read almost every topic here dealing with pumps & wells, I did not see one with my perticular problem, if it has already been addressed here and I overlook it then I appologize.
We have two wells, one well is a deepwell which has Iron water. the other is a shallow well which does not have as much Iron as the deep well. When we purchased our home last fall (2005) there was a old house beside the one we live in. Our home had already been started just roughted in, but the prevous owners already had the deepwell ran to the new house, so we hooked into it..All has worked fine untill about 5 days ago, the deepwell went dry.( we had not had rain in 3 weeks) after a day or so it kinda built up enough to flush a commod or run it for justa few mins then it would be out again..
We decided to run the shallow well into the house, it already had a 1/2 horse pwer pump but when we had the old house tore down we disconnected it and put it in building, after having it all hooked and all, the pump pumped but the pressure would not build up (40 is what it is set to) it would only hit round 28 or so..the pressure tank is only 1 1/2 yrs old along with the pressure switch, checkvalve, and all the other stuff involved there.(sorry dont know the correct temology). after the pressure would only build to 28 or so the pump would not cut off , it would just keep running..We thought it was the foot vaulve gotta new one. still didnt help. someone told us it was probably the pump wasnt strong enough..to pump 12'up..70-80' to house..so we went bought new pump..Shur-dri 1hp shallow well jet pump.got it all hook up..
now when you kick it on it clicks..pressure doesnt really build up. it has a pressure switch preset on it..if you hold a button in it will run if you do not it will just kick on and off consitanly..we have checked everything we can think of and still not sure how to fix this..if the pump does run (after adjusting the pressureswitch on tank) it doesnt kick off and the pressure tank doesnt seem to have/hold pressure.
hope that makes sense...termology and relating thinking to typing is a great task..
any suggestions would be greatly appreicated,Thank you for your time and input..
