I'm remodeling my master bathroom which was built back in 1989. The current setup has a dividing wall between the shower and the toilet. Running up through that wall is a 3" vent which connect with another 3" pipe up in the attic and eventually makes its way out through the roof. My wife and I were hoping we could remove this dividing wall so that we could install a three sided corner shower. I figured it would be no problem to just cut out the existing wye install another one facing the other wall and run the vent up that wall. My problem is that there is only about 6" from the center of the drain to the sheet rock on the far side of the wall.This doesn't leave enough room for a 3" 90 degree turn. I then thought maybe i could use a step down wye and use a two inch vent pipe. But after buying the pieces today I'm thinking I'm going to be slightly short on room to make that 90 degree turn and still have the existing drain lines line up straight. I was wondering if anyone had any experience with this situation. Could I maybe use a series of either 45 or 90 degree bends to "bow" the vent connection out away from the wall or is that a terrible idea? This forum is my last hope otherwise I'm stuck with the wall. Any advice either way would be much appreciated.
This shows the dividing wall.
This is a picture of the wye. The toilet drain line is coming from the right. The shower and the toilet both share the 3" vent.
