Results 1 to 2 of 2
Thread: How to pick right size taco pump
    Default How to pick right size taco pump
    I'm going to have 3 separate pumps for 3 zones,BB hot water,gas. Do you establish a flow rate for each zone (f=Q/500 X 20) (http://www.taco-hvac.com/uploads/Fil...rculators.pdf). The f that you get,you are suppose to go to the chart and tells you the size of pipe. Is this pipe size the size that is suppose to go into the pump and or the pipe going out of the pump.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Quote Originally Posted by JOE1934
    It is the size of the pipe/tubing in the circuit. In most cases the pump will be the same size but could be larger.
