Model T Nut
- Messages
- 3
- Reaction score
- 0
- Points
- 0
Hello and thank you for reading my post,
I am in need of some advice from the experts. Here is my predicament.
My system is making a loud bang on startup and shut down of the pump. The noise is now quite loud at times and is more likely to occur on shutdown than on start up but has gotten louder and more frequent with time. It sounds like a bad water hammer but a little more metallic in nature. Although it sounded like it was coming directly from the well to start with, I started by trying to make sure it was not just a pipe hitting a floor joist or any other clearance issue.
It has been suggested to me that it could be a problem with the check valve down at the pump in the well. This sounds plausible considering the symptoms. Is this a common problem? I believe the pump is original and the house was built in 79 so I planned on replacing the pump and check valve (and possibly the pipe, ect) with pulling it up.
I work in a service field and I’m currently between jobs so I decided to do the job myself (with an extra pair of hands). The cost of the parts is enough of a financial burden at this point in time.
This is where problem #2 comes in. I can not get the pitless connector to release. The 1” pipe that is threaded into the top of the connector is cut off about 2” below the top of the casing. I have not been able to unthread this pipe as of this point to be able to install a T pipe for better lifting. Pulling up while wiggling the pipe to try to get the coupling to release has been fruitless. I have a good sized slide hammer that connects to a vice gripes. I was able to clamp on the end of the pipe with it but even that in combination with a crow bar prying upward on the clamp did not get it to lift up. I didn’t want to get too brutal with the blows at this point as I was wondering if some types of pitless fittings release in a different way. Also, the lifting pipe is galvanized but I can’t say for sure that the pipe below the coupling is also galvanized or its condition. There does not seem to be a safety cable or rope going down to the pump and I would hate to send my old pump down to a watery grave in my well. I can not see any fasteners on the pitless but it is about 4+ feet down and a little hard to see detail. It does not look like it has a flange were the two halves would slide together like most of the ones I can find on the web. Looks more like a standard T fitting when looking down the well. Any suggestions?
The following are some specs and general information on the system I have so as to paint a more complete picture.
The well is 168’ deep
Static water level 25’
Pump set at 42’
7” well casing 8’ from the house
Pump size ?
Two wire, 220V pump
Copper plumping system
1” line to pressure tank, ¾ from tank
35 to 55psi cycle pressures
I need to add that it appears I also have developed a small hole in the bladder of the expansion tank (when it rains, it pours). I have been having to drain the tank and recharge it every couple of weeks now. I need to replace it of course, but money it tight and I have been keeping an eye on it, fully draining it regularly then setting it to about 33 psi for the time being. I do not believe I have much of any water above the diaphragm at any given time and recharging the tank does not have any real effect on the banging noise, just the cycle time.
Thank you for any input you can provide.
Pump set at 42’
Pump size ?
Two wire, 220V pump
