Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Thread: Are ther alternative to Wooden Post on Deck Foundation
    DIY Member herbolaryo's Avatar
    May 2007
    San Francisco
    Exclamation Are ther alternative to Wooden Post on Deck Foundation
    The Deck "wood" post that is nailed on the cement foundation is rotten.
    I understand there are synthetic deck materials made of some kind of plastic for the deck flooring.
    Sometimes its hard to keep up with waterproofing and is costly.
    Are there similar materials for the deck "wood" posts?
    Is there a way to make the wood post resistant to rot?
    Synthetic materials generally aren't strong enough for a support, so no. You could use steel. There is hardware that holds the bottom of the wood post up away from the concrete, and allows air to circulate. Using one of the pressure treated woods and the fixtures to hold it up off of the concrete should allow it to last a long time.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    You can get away with plastic deck boards by limiting the joist spacing but it is not good for structures. It is not stiff enough.
    The ends of posts should NEVER be put against concrete. The best is to put them on heavy galvanized supports that are cast into the concrete. The supports keep them about 1/2" off the concrete. You can also use "earth contact rated" pressure treated plates under the posts but you need straps for a good attachment to resist uplift.
    All wood material should be pressure treated. The safest for the posts is to get material that is certified for earth contact.
    You can use steel posts or even reinforced concrete. That is a lot harder for a DIYer to work with. I helped my son put in a low deck and we ran the concrete piers from below the frost line up to the beam heights with a 1/2" threaded rod extending down and up enough to both reinforce the pier and serve as an anchor bolt.
    The steel backing of old disk brake pads makes a nice big "washer" to hold down multiple 2 x 8s or 2 x 10s used for beams.
    May 2007
    San Francisco
    Exclamation
    Quote Originally Posted by jadnashua
    Thanks jadnashua for the post. Can you tell more about the hardware at the bottom... I am a bit of a beginner in terms of deck...
    May 2007
    San Francisco
    Exclamation
    Quote Originally Posted by Bob NH
    Thank you Bob NH for the post. Can you explain further about the heavy galvanized support... How do I make that? Or is it bought ready to place?
    Any big box store generally carries them...you don't make them, you buy them. It bolts to the concrete pier and then you bolt the post to it.
    Nov 2006
    Somewhere I have seen "highchair" post pads that look kind of like a small bed of nails/legs/fingers that sit on the concrete and keep the post up an inch or two ... but tie-downs would have to be added somehow.
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default More deck post/material questions
    Hello all,
    This post leads to some more questions regarding installing deck posts. I live in Nw York St. where the frost depth can easily reach 4' below grade. For deck posts, I have seen people use sauna tubes filled with concrete, and I have seen some put the pressure treated posts directly into the ground and tamp every couple of inches as they backfill. I have seen the sauna tubes filled with concrete be lifted out of the ground by frost, and I would assume that eventually the deck posts will rot.
    1. What is the best way of installing a deck post that will last for 20 + yrs?
    2. Also, with this wet and cold climate, wooden decks are constantly being maintained on an annual basis. I have seen the synthetic deck boards and rail systems. Are these systems framed with traditional lumber (pressure treated), or are they framed with synthetic materials?
    3. Can anyone recommend a good synthetic deck brand/line?
    TIA,
    Molo
    Plumber jimbo's Avatar
    As already stated, synthetic materials are not structural. The best structural material is pressure treated lumber.
    If you put posts in the ground, the life expectancy would probably be stated at about 10 to 15 years. Life expectancy of any wood planted in cement is 5 to 10 years. The best bet is pressure treated wood posts placed on concrete footers of appropriate, using the post base which keeps it away from direct contact with the concrete. This probably gives you a life expectancy of 20 years. You just can'y really build a deck that is going to last forever. Too much exposure, too many variable.
    With pressure treated, remember that every time you cut it, you need to get a can of the "green stuff" and brush it on the cut.
    The key to any footing is that the base needs to be below the frost line. If you don't go far enough, or the soil is not good enough for that foundation, you'll get those results. If there is clay or a lot of ground water, you need to potentially ammend the soil.
    If you use one of the strong-tie products to hold the base of the PT wood up off of the concrete, it should last for a very long time.
    There was an article on synthetic decking in Fine Homebuilding in the last year. You should be able to find it at a library, or maybe a friend, or order it on-line. It compared many of those available.
    Many of the railing systems stand alone for the rail and stiles, but the posts are a cap for PT wood. Not all, though.
    dampness when it freezes can crack anything! as long as damp air or moisture can get into it and seep in.
    go real far north, like halfway to the North Pole, and you see they only use concrete for the lower half of the structure. Utilities antennas, goverment piers and docks, everything even houses all have concrete bases, or full basements, and the concrete goes up a few feet above ground.
    assuming the dock is built to last. governments always want to look like they are going to remain the authority, so they want to build to last. Also, in the long term they have much fewer problems with maintenance and responsibility concerns if it's made tough.
    There are hundreds of kinds of concrete products. Some have a lot of air in them, some have none. Damp air will let H2o get in and crack-freeze in winter and spring.
    A single long freeze is not a problem, so a long cold winter causes almost no damage. In the fall, as temperatures drop the moisture content in the air also lowers slowly, so there is less and less moisture in the ambient environment too, so the first big loong freeze causes no damage. The worst thing is if moisture is in the concrete in spring -- when daily cycles between thaw and freeze let water percolate (slide around) which lets it occupy (like "expanding") into the micro fissures, and then it applies brand new pressures overnight when it freezes. Repeat for 45 days and you have aged your concrete the equivalent of 100 winters. After ten springs (ten years) your concrete could have aged as if 1000 years old, or it could be fresh and new looking, and it all depends on whether you managed to keep it dry in February, March, April and May when the sun is strong during the day but the night time temperature is below freezing.
    david
    Dec 2006
    As far as post straight into the ground go, be aware that there are different grades of pressure-treated, depending on how much of the chemical has been injected into the wood.
    Some pressure-treated is just rated for "outdoor exposure" - ie, deck framing
    some is rated for "ground contact" - retaining walls, etc.
    some is rated for "foundation" - pile foundation under coastal homes
    and then there's "marine-use" - piers, docks, pilings
    DIY Member Backglass's Avatar
    Jun 2007
    New York
    Quote Originally Posted by herbolaryo
    A picture is worth a thousand words!
    There are other, similar brackets. The one I was referring to has an upside-down u-shaped channel with a bracket that holds the post. This raises it above the concrete and gives it a good chance of staying out of surface water, or if not, then drying out later since it is not in direct contact with the concrete. The main component of all is that the post is not burried in the concrete which often creates a cup to hold water against the wood for extended time and leads to rot.
