Thread: Rough-in ?
    Default Rough-in ?
    Hello,
    After tile installition I have 13 3/4" +/- 1/8 Can I still go with a 14" rough?
    I am thinking of using the TOTO Carlye with the 14" UniFit any thoughts or comments?
    Thanks for a great info source
    David
    If I remember, on that toilet, it has a normal 3/4" clearance behind it. You should be able to find the line drawing on their spec sheet on the website. I'm pretty sure it will fit, but have a little less than the nominal clearance, which isn't a problem.
    I think most, if not all, toilets allow for a bit of space behind the tank. This gives the installer a little leeway.
