Hey all,
I have a question to ask you. I think I'm doing this right because one side is right. I had these 2 'garden' type valves in the kitchen and I had to get rid of them, putting caps on them while I redo my kitchen. I used the pipe cutter on both and did the hot side first. The cap went on nicely using the torch and solder. The cold side is where I'm having trouble. Before I start to sweat this side, I blew into the pipe and heard water coming up. So I did that till no more water came out..but you can still hear something wanting to come up but it was dry. Putting the cap on with the flux, heated the pipe/cap, and then put the solder on the ends and watched it suck in. Waited 5 min, then turned on the water, guess what? It was springing a small pin hole leak. Waited 10 min, heated the cap, took it off and cooled down the pipe/cap. Had the wire brush, cleaned everything off and tried again..i'm still leaking! Is there water coming up that I don't know of? I'm sitting here blowing in till no water comes up. I even tried to heat the pipe up with another cap to see if steam comes out but nothing. Should I try to stuff bread in this pipe? Sorry for the long rant..
Andy
Andy
