Results 1 to 5 of 5
Thread: Using Sump pit and pump for lawn irrigation
Hybrid View
    Default Using Sump pit and pump for lawn irrigation
    Water rates and enviromental awareness have me wondering if I can re-direct my current sump pump discharge from the storm drain to my lawn irrigation system. I have read where people will pump to a cistern and then use a pump from the cistern to their lawn irrigation system, I am wondering if I can use the water in my sump pit the same way and by pass the cistern. I am concerned about pressure to irrigation system, do I need a filter?, can I have multiple pumps in the sump pit?, I still need sump pump protection during extreme wet conditions. Any suggestions, designs, recommendations, or comments are welcome. Thanks
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    1. Yes, you can pump the water from the sump to the lawn.
    2. You shouldn't need to filter it if you have a good sump.
    3. When you have the most water in the sump, you won't need to irrigate.
    4. A sump pump will not provide enough pressure for a sprinkler system.
    5. You can put an additional pump in the sump. You could use a shallow well jet pump and just drop the suction pipe with foot valve in the sump.
    6. You will have to protect the pump by using a float switch to operate it.
    If yr pumping water out of the ground, the last thing you want to do is put it right back into the ground. A better way is to pump into a cistern until it's full and then have the overflow channelled away from the house - far away if possible.
    An even better way is to channel your downspouts AND your sump into a cistern or rain barrel.
    You only release the water from the cistern on a dry day. The best way to use the stored water is for drip irrigation or a soaker hose around flowers/plants/trees. Those systems don't require much pressure and require much less water than the lawn. If you use the cistern on the lawn, it'll empty fairly quickly, at which point you'll require a valve to switch to city water.
    (important note: I'm not a pro)
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    You don't nourish an extensive amount of landscaping with sump water. The cost of setting up enough storage would be excessive.
    DIY Senior Member Mr_Pike's Avatar
    Jun 2007
    Nebraska
    It has been done, and is kinda spendy to get setup.
    You will definetly need a pressure rated pump, a sump pump is definetly not.
    Your irrigation system is likely designed for municipal water supply capacity, Something like 15 gallons a minute at 40+ lbs. Your sump will not likely provide this kind of water. The options are the systern for capacity storage like stated above, or design the irrigation system from scratch to operate on the GPM that the sump is capable of providing. You have to have one heck of a sump to pump 5 GPM constantly.
    Simple solution is to put a cheap spray type lawn sprinker on a hose. Something with little to no back pressure. Connect that to your output on your sump. Be advised that this will shorten the life of your sump pump, and should not be attempted with a cheap plastic pump.
