The tub should be supported and should not rock. If the feet are structural and not just decorative, then they should all be in solid contact with the floor. If not, the tub may not drain properly, or it may rock and crack the connection to the drain, or break the caulk seals to the walls which could admit water around the side of the tub, or all of the above.
If it were me, I'd put a layer of SLC on the entire bathroom floor to achieve level.
