JasonRay
I just bought a rural property near Portland, OR that has an existing 8GPM well. The pressure tank is in the basement of the house about 100 yards away. The well head and the above grade plumbing around it were left completely exposed, and we get many days of below freezing temperatures in the winter. The previous owner put an uninsulated plywood box around the well head and ran an extension cord from the house to power a small heat lamp to address the issue - after some of the above-grade PVC pipes burst.
I want to build an attractive and heavily insulated structure around the well head. My wife's wish list says it should be a stone-exterior "wishing well". No matter what it is, I need to figure out a couple of things:
1) If I pour a small slab for a structure, how much exposed ground around the well head should I leave for access?
2) How much space around the well head, above grade, do I need to leave to it can be worked on if necessary?
I need to install some permanent structure if I am going to run a circuit out there for any kind of heating. I suspect that given Portland temperatures rarely fall below +20F a properly insulated enclosure with some ambient heat collection might retain enough heat to eliminate the need for a heat lamp - but that also demands a more permanent structure.
I saw one comment in this forum that a well house should leave at least 5' in all directions from the well head, although I have seen many well houses that are smaller. Any advice I can get would be much appreciated.
