Rick.a
I have to fill out a useless but required real estate form that asks what is the "Gallons per minute capacity of your well pump" How can I get this accurate? If I do the "fill the 5 gal bucket" method, it will only measure how fast my tank can push water out since it has a 5.9 gal output.
Pump is 1/2 HP Goulds submersible at 200 ft, with a Well X Trol 202 tank. If I do the test at the low pressure end of the tank (30-50 switch), the pump will kick on during the test. Will that give me different results (shorter time to fill).
thanks,
thanks,
