caleb said:
.... the same just 4 inches lower.... The drain is low in the wall and soldered at the wall level ....
Tubular is the key word to use when you search the web. And 1-1/2" Use 1-1/2 as the key word, with the hyphen.
The big question not answered in your quoted text above is whether the Tee connecting the drain into the wall pipe is at the right height. You said it's low, but that may just be a beginner's view. It
has to be at the same height as the end piece coming out of the P trap. Then water flows out of the P trap and into the wall pipe. A slight slight slope can be good too, something like 1/8" drop. Take another look, and you ought to see that the Tee is at the same height as the P trap's tail. Otherwise, take pictures and post them so other people can comment on what you have.
When you rebuild the same just 4 inches lower, your water coming out the P trap goes on a flat line, in a horizontal pipe, with or without that minor slope.
This means you have to cut and reposition the Tee in the wall pipe, four inches lower too. This is serious; it must be done.
What you had before was chromed brass, chrome plated brass. It's good stuff, it'll work again, it'll be easy to install since it has slip joints that you turn by hand, and so I would reconsider whether or not to use this same material again.
Other people will tell you how to mate PVC to pipes of other materials. Search "tubular". You'll see PDF catalogs showing both brass and PVC, and many different adaptors and connectors.
david
