I got my water system as follows
1HP self priming pump connected to the municipality water mains 1" pipe
Pressure tank 24 Liter
Pressure switch set to 50/70 psi
It happend few times that the water main has very little water to the extend that the pump can not fill the tank and reach to 70psi to shut itself off and keeps running untill i discover that by chance
In a trial to protect the pump , I bought a Flow Switch (Watts) model FLU25/ST it is a (paddel type)and I intended to fix it before the pump to see the low flow and connect it in serious to the pressure switch to cut the electricity feed to the pump when the flow is low.
I read the data sheet of the Flow switch but I found it meant to be fixed after the pump obviously to feel the high pressure of the pump which should feed a boiler then switch off the boiler when the pump dischanre is under certain limit ( the setting of the switch )...this is what is written in the Flow Switch data sheet.
The question now , can that flow switch work in my case too ? with that water mains relatively low pressure which can be as low as 10psi?
I want to know that before I fix the switch in the system and incur costs and effort then if it did not do the job I would not be able to return it to the shop.
Thanks very much in advance!
