The benefit from ABS to Cast Iron is that Cast Iron will build up like a clogged artery. The drain will get smaller and smaller but can be cleaned with a jet drain washer.
The pipes will not freeze and burst because with a drain as apposed to a pressure pipe it's not full of water.
A 2" line is fine for what you have.
You can use both at the same time if you want to slowly change over slowly.
