There could be something else, but it sounds like possibly a ground wire problem. The valves share a common ground wire, they are daisy-chained from valve to valve. If the connection was broken along that chain, the first ones in line would work fine, but the ones after the break would not. The connections are make using either special wire nuts that have a sealant inside or a regular wire nut and silicone.
