Results 1 to 6 of 6
Thread: Converting a pumped recirculation hot water system to GRAVITY
    DIY Member luc's Avatar
    Apr 2007
    Quebec, Canada
    Default Converting a pumped recirculation hot water system to GRAVITY
    Hi everyone,
    We have a hot water recirculation system with a pump and I would like to know if I can convert it to a gravity recirculation system without a pump.
    The building is 40' x 100' with 3 stories. We have 3 copper hot water supply lines of 1 1/2'' and 3 return lines of 1/2''. The 3 return lines connect together on a 3/4'' line with a flow check valve which then connects to the cold water input and the bottom of the water heater.
    Luc
    Plumber jimbo's Avatar
    Turn off the pump overnight. If the gravity thing is working, which it may well be on 3 stories, then just leave the pump off;
    Apr 2007
    Quebec, Canada
    Hello jimbo,
    I turned the pump of for a few hours yesterday and the tubing got colder on the return lines. I've heard that we need to drill a hole in the check valve for gravity recirculation to work. Also, since I have 3 return lines I would probably need to have a check valve with a hole on each return lines.
    Luc
    Default circulaton
    Since the system has a pump on it, there is little likelihood that the piping was installed the way a gravity system would require it to be installed.
    Well, accidents do happen! My daughter just had a copper repipe to bypass all the underslab copper. She contracted with the general who is doing a large addition on the house. Since all the walls and ceilings were open, they put in an isulated recirc return with pump. There is no electricity yet, pump not plugged in. That sucker is recirculating like all get out! Just an accident, I guess!
    Apr 2007
    Quebec, Canada
    Thanks everyone for your replies.
