barumord
- Messages
- 9
- Reaction score
- 0
- Points
- 0
I recently built an addition to my home. The new basement was built about 1 foot lower than the existing basement with footing drains transfering water to a pit outside my basement in the backyard. My problem is as follows, the pump keeps overheating or tripping the fuse. I have gone through 3 pumps now (in 1 week) and I suspect it has something to do with the electrical connection. FYI, since the pump is connected outside the basement, my contracter connected it with an extension cord. He claims it is a 12 gauge cord (about 25 feet long) and should be able to handle the load. Now I know the pump manufacturers state not to use cords. Can this be the cause of the problem?
Also, we get ALOT of water in this pit. I want to replace the pump with a new pump that is capable of pumping large amounts and can also handle the constant on and offs (about every 10 seconds). I dont want to have any problems in case leaves, dirt or pebbles get sucked up. Can someone recommend me a good reliable pump for this? Thanks
