Chefwong
Gawd Awful Rialto - flapper or valve
I've had the Rialto for about.....8-9 years now I think.
It was a basement remodel.
Since then, I must have replaced the awful flapper 2X and the valve 1x - cause the awful thing decides to leak every now and then. It's the darn flapper that doesn't sit right but each time you look and check, it's all good......
So for the umpteenth time, what do you guys suggest. Get a OEM flapper or the Korky equivalent that would fit ? Or should I swap the valve out as well......
The next time this things need service....the sledgehammer is coming out ;-)
