Results 1 to 8 of 8
Thread: faucet washers...different grades?
    DIY Senior Member bbillcee's Avatar
    Feb 2007
    NY
    Default faucet washers...different grades?
    I have an ancient gerber faucet....i recently installed new stems and seats
    the hot water keeps going through washers
    could it be the washer is not handling the heat?
    any suggestions?
    do they sell a premium type of washer? or specific for hot water?
    Apr 2005
    Black rubber washers until they harden from age are susceptible to tearing/ripping.....especially if the mating surface that they come in contact with have a chip or sharp edge on them.
    I only use composite washers; they usually are pastel colors.....a great deal harder from the go and wear like iron opposed to black rubber.
    Default washers
    There are rubber, synthetic, fiber, neoprene, and teflon washers, among many others. But none of them should do what you indicate.
    Check the new seat you installed to make sure there's no cuts or imperfections on it. Make sure the new valve stem has no defects that could slice into the washer. Above all, make sure the valve stem is in the open position when you screw it in or else you can really squeeze the life out of the rubber washer before it is ever used.
    Feb 2007
    NY
    thanx for the info....so the best washer is the composite?
    Apr 2005
    Plumber plumber1's Avatar
    Aug 2005
    Florida
    You have a seat problem....
    Default washer
    Composite is the hardest so it will take more effort to turn off completely, and if it leaks it will damage the seat before the washer is affected.
