novice 1832
- Messages
- 4
- Reaction score
- 0
- Points
- 0
I recently installed a new Quarter Master, quarter turn sillcock. Since I installed it by soldering, I removed the stem and then replaced it after everything cooled. Now when I connect a hose and turn the faucet on, water streams out of the stem near the handle. Did I re-install the stem incorrectly? I removed it and re-installed it 2 or 3 times with the same result. I also cleaned a small amount of solder out of it. When the valve is shut off, there are no leaks.
