Results 1 to 8 of 8
Thread: Sanitary Tee on side?
    Default Sanitary Tee on side?
    A wye and 45, sometimes called a combination fitting or combo.
    I've googled to the end and couldn't find a definitive answer, so I'm hoping to get it here.
    Santee
    Is it possible to use a sanitary tee in a waste line on its side? I'm doing this to change directions/tap into an existing waste line.
    and from the differing answers I found, none of them gave a clue as to why this can't be done, other than to say it can't be done.
    In the Trades kordts's Avatar
    Oct 2005
    exurban Chicago
    You need a wye, or tee-wye. A horizontal to horizontal change of direction needs to be sweeping.
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    the turn radius on a san tee is too tight, it will eventually have a problem with clogging.
    thanks for the quick replys.
    Sometimes, google isn't the best place for information.
    Quote Originally Posted by kordts
    What about vertical to horizontal ? (Although I could feel advantage of
    45+wye in this case as well)
    vertical to horizontal, wye
    horizontal to horizontal, wye
    horizontal to vertical, santee or wye unless the vertical is used as a vent, and then a santee.
    Are combo's OK? The type that is like a "T" but has a sweep 90 sort of with it?
    This is for a horizontal to horizontal.
    Ron
    Oct 2005
    exurban Chicago
    Yes, a store bought combo is also known as tee-wye. I hadn't seen them until recently, we made them up and always called them combos.
