nagr22
I moved into this place about a year ago and I am currently replacing an old pump with a Gould 1.5. There were two new bladder pressure tanks installed before I moved here and only one tank seems to be filling. I checked the air pressure for the bladders and they were both apparently set at 30 lbs. and the pressure switch comes on at 32 and shuts off at 42, and the tanks both measured 72psi when the pump shuts off which is fine. However, with the new pump I will need the additional storage of the other tank which is not working correctly.
My understanding is to shut of the pump, drain the water from the tanks and then set the bladder pressure 2 lbs below cut in. I plan on replacing the pressure switch with 40-60 and want 45psi so would set the bladder pressure in both tanks at 43psi. Is there anything to do differently because there are two tanks?
