Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: Q re venting basement bath
    Question Q re venting basement bath
    I am installing a basement bathroom and want to make sure I properly vent. I need to tap into a 4" drainpipe that runs across the basement floor. This pipe provides drainage to a 1/2 bath on first floor, and runs across basement floor to the main stack that drains upstairs bathrooms and kitchen, and vents out to the roof. The bathroom is to be installed in the corner of the basement where the pipe comes down from the 1/2 bath. This pipe goes to that bath but does not vent out to the roof.
    So, I need to put three Wyes into this 4" inch floor pipe. One 3" Wye that will run to the toilet, one 1.5" or 2" Wye that will run to the sink, and one 2" Wye that will run to the shower drain. Toilet is within 3' of sink, and shower drain is within 8' of sink.
    Given that background, which I hope makes sense, I have been told various things on venting: (1) Given the nature of this floor pipe, which ultimately connects to the house's main vent stack (about 15' away from bathroom location), that I don't need to provide extra venting at all in this basement bath; (2) That I need to pursue much more complicated venting of each drain (toilet, sink, shower); and (3) That I could put one AAV (mini studorvent) in the sink cabinet, on sink drain pipe, and that AAV will provide sufficient venting for the whole bathroom. I like option 1 but it seems too good to be true. I like option 3 as well.
    What do you think of these options? Thank you for any guidance you may have.
    scratch-pad engineer and mechanical fabricator leejosepho's Avatar
    Nov 2006
    Quote Originally Posted by Soke
    ... a 4" drainpipe that runs across the basement floor ... provides drainage to a 1/2 bath on first floor, and runs across basement floor ... and vents out to the roof.
    I have been told various things on venting: (1) ... that I don't need to provide extra venting at all in this basement bath;
    My guess is that the vented 4" pipe will accept your new bathroom and work just fine without any additional venting, but I can see how a flush from above at least *might* make the AAV necessary.
    Thank you very much for your reply. I am recovering from a bad contractor who installed Wyes the wrong way and I ended up with sewer from the 1/2 bath all over my basement. I re-dug up the floor, removed his PVC work, and put in a straight line as a quick fix, and now am trying to complete myself. I didn't trust the fact he planned no venting. I will need an inspection from the county but would like to do it right the first time. Thank you again.
    Let's back up minute. You describe the main stack in the corner as the pipe bringing the waste down from the upper floors. If so, that is not a vent stack. The portion of it way up above which goes to the roof is a vent, but the lower portion carrying waste is not a vent. It sounds like you have NO vent down there, and that is definitely not acceptable.
    Air admittance valves might be accepted in your jurisdiction, but are an invitation to an ugly mess if you have a main backup and the studor leaks.
    Nov 2006
    Quote Originally Posted by jimbo
    Let's back up minute. You describe the main stack in the corner as the pipe bringing the waste down from the upper floors ...
    I believe what he has described is a 4" line across the basement floor, with its beginning end receiving waste from the half-bath above the proposed new basement bath, and with the pipe's other end being vented out through the roof while receiving waste from the kitchen and main bath above its outlet.
    So then, and assuming the half-bath has no plumbing problems, the question is whether a new bath directly below it in series would have/cause any new problem.
    Nov 2006
    I am recovering from a bad contractor who installed Wyes the wrong way and I ended up with sewer from the 1/2 bath all over my basement ... I didn't trust the fact he planned no venting.
    Were that bath and the wyes originally installed together, or was something later changed or added?
    Thank you all for your help. I need to run to kids' soccer games but will come back later today. Leejospeph is correct in his description, this will be under the 1/2 bath. Basement bath is new, being installed into original cast iron piping that runs across basement floor. Thanks again.
    Sep 2006
    Phoenix, AZ
    1st - you will have to have some sort of venting in the new bath...
    You cannot rely on either of the lines going to the upper floors for venting as they are waste lines...
    That would leave either studor-type vents or (preferably) actual venting lines that would tie into the upper floor vents before exiting the roof....
    The min size you could use for the vents is 2" - that would be sufficient if you could tie all the bsmt vents together and just run it up to the vent tie in...
    Thanks everyone. I double checked and the 1/2 bath on the first floor, under which the basement bath is to be installed, does have a 2" vent pipe out through the roof. I was incorrect in my first posting.
    Default venting
    #1 is totally incorrect
    #2 is the ideal
    #3 may be an option DEPENDING on exactly how the piping is installed. What you describe, how we interpret it, our suggestions, and how you actually install the piping could be vastly different.
    Nov 2006
    ... the 1/2 bath on the first floor ... does have a 2" vent pipe out through the roof.
    How did you end up with sewage on the basement floor? Had something that had been roughed-in later back up and leak?
    We hired a contractor to do the bath. He was incompetent. If the below picture comes through you can see how he plumbed it in -- note that the water/sewer from upstairs runs from top of picture to bottom. He did this and cemented over it. The next day (a Saturday), while my wife and I were wondering how the inspector would judge things, we went downstairs and found the mess on the floor. He plumbed in two Wyes backwards so the sewer/water just flowed right out. (Turns out he of course never applied for an inspection as we had asked.) I dug it out and found it as the picture shows.
    (There was also a clog dowstream I had to snake out)
    Thanks. If you can view the picture below you can see how the line runs (this is what I removed and have to redo). But I will have to install sink wye first, then toilet almost adjacent (I would not do the 90 degree anlge he has but run toilet line straight into the wye), then finally the wye for the shower a few feet downstream. Thanks for your help
    Nov 2006
    I will have to install sink wye first, then toilet almost adjacent (I would not do the 90 degree angle he has but run toilet line straight into the wye), then finally the wye for the shower a few feet downstream.
    I do not always do things "by the book" when I am quite sure they will work in spite of my deviation, but even I would not do what you are planning without first finding out precisely what fittings are actually proper, how they should be ordered and oriented, and how to add some venting.
    i like the way that was said.
    You do have to use San-T fittings for sinks, for example, and I notice the thread originator said "Wye" in the quoted text.
    Soke, there could be more places where we can help but you may be moving too fast, describing too breezily. Take it one small step at a time.
    david
