Results 1 to 5 of 5
Thread: Adding a Tee to an existing 3 inch PVC Line
    Default Adding a Tee to an existing 3 inch PVC Line
    I am installing a new sink and would like to know if it is code (per 2003 IPC)
    to us a fernco instead of a repair coupling to add a tee to an existing 3 " line? I am wanting to add a 3" w/ 2" tee with a 2" to 1 1/2" reducer to then attach to the sink. At first a saddle tee looked promising until I looked at the other threads. My plan is to cement the bottom of the tee to the existing stub, cement a short 3 " piece to the top of the tee, then use the fernco to sew it up.
    Thank you in advance for any advice/information!
    Rob
    Use a banded coupling rather than the Fernco. A Fernco is not supposed to be used above ground. The banded coupler is similar to a Fernco, but it has a stainless steel band the full length of the sleeve instead of just the two clamps on a Fernco.
    Thanks Gary! Do they sell those a the "Big Box" outlets or do I need to hit my plumbers supply?
    Can't say for sure, but Big Boxes should have them.
    Smile
    Gary,
    Thanks again for the info.
    Rob
