Hello Folks,
I have a deep well and just replaced the ancient stuff that was in there after the pump lost prime and a screw driver went through old pipe while trying to clean it off.
History: We move into this house about 2 years ago. All was well until we got nailed by a hurricane and lost power. When the power was restored I got me first taste of having a well as it lost prime. I finally got it to work and all was well until I lost power again. Each time, every couple of months for whatever reasons it would loose prime. The last time, a couple weeks back, the motor just kept running and would not get past 40 pounds of pressure. When I started to take a look at things I began to remove some corrosion and my screwdriver went through the pipe. So I removed everything, after seeing what was in there I couldn't believe it worked to begin with.
I replaced everything: A new Flotec 1 HP deep water pump on a 2 inch well with a Flotec 42 lb Bladder Tank. All was well until today, a week later when all of the sudden the pressure dropped to almost nothing. Now it keeps running like before and wont build pressure beyond the pressure from my neighbor’s hose, 40 lbs, I can turn it off and it will hold the pressure very well. Mine is set for 30 and 50.
I'm stumped; any help will be GREATLY APPRECIATED!!!
Thank you in advance,
Gaddock
Gaddock
