Results 1 to 5 of 5
Thread: Saddle Valve into flex water supply line?
    DIY Junior Member kine97's Avatar
    Mar 2007
    Indiana
    Default Saddle Valve into flex water supply line?
    We are going to change out our Kitchen sink & faucet. We want to use the flexible Faucet Supply Lines, but don't know if we can tap into the cold water flexible faucet supply line with a Saddle Valve to run water to the Ice Maker. Does any one know if it is possible, or do we have to have some type of rigid water supply line running to the cold water side?
    We're also wanting to run an under-the-sink filter to a separate filtered faucet. We will use a shutoff valve that has two 3/8'' comp. for the 2 different faucets on the cold water side.
    I hope all this makes sense.
    Thanks in advance for any advice.
    Theresa
    Default supply
    Saddle valves are NEVER a good choice and will definitely not work on anything other than straight hard copper. Use a "3 way" valve which has two outlets, either both 3/8" or one 3/8" and lne 1/4", (this is more common and useful for water filters, etc.).
    DIY Senior Member TedL's Avatar
    Sep 2006
    NY Capital District
    If you don't want to change the valve, buy or assemble a Tee/manifold that will screw on to the existing valve and give separate connections for the two lines.
    Commercial Plumber markts30's Avatar
    Sep 2006
    Phoenix, AZ
    You can use a 3/8" X 1/4" compression tee on the faucet supply...
    Run from the valve to the T and from the T to the faucet 3/8"...
    From the branch serving the appliance (1/4"), run a piece of 1/4" copper and then a 1/4" shutoff valve (compression...) then run to your appliance...
    Default tee
    If you are going to install a tee, use a BrassCraft "add a tee" that fastens to the valve and then the risers connect to it.
