Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: Toto Soft Close Repair?
    DIY Junior Member gerlando's Avatar
    Apr 2009
    Washington
    Default Toto Soft Close Repair?
    One of my soft close seats has stopped functioning correctly after maybe... 2 years of use. It sounds like something within the hinge broke and it drops almost as fast as if it were a regular hinge. Are these repairable or do they need to be replaced? I tried searching online and only found other seat failures with no resolution. 2 years is way too short a lifespan IMO.
    Call Toto...I don't think it can be repaired.
    Customer Service Manager Plumbing Wholesale Peanut9199's Avatar
    Apr 2007
    Ontario, Canada
    No they can't be repaired.
    Where are you located?
    Apr 2009
    Washington
    Default Soft Close Repaired!
    I decided to take the plunge and take the seat apart to see if it could be repaired and guess what. They can be repaired, and rather easily. At least in my case, once it was all apart I discovered the liquid in the hinge must have leaked out which was causing the failure.
    I took photos with my phone along the way, but they didn't come out too good.
    Basically there are two hinges, one on each side. One hinge controls the top cover and the other controls the seat. To get to the hinge you need to pull the hinge pin out of the over and seat. There are two plastic prongs that hold the pin in, but they can be bent open so the pin slides through. Once that's done there's another plastic prong that holds the hinge in the middle bracket. Once the hinge is free it can be pulled apart by removing 4 screws. The inner screws have tiny o-rings on them so make sure not to lose them!
    Once the hinge was separated I noticed it had a viscous fluid that's basically squished between two sides of a channel. This provides the slowing mechanism. But mine was leaking and most of the fluid was gone. I refilled the hinge with some automotive grease figuring it was as close in viscosity as I had in the garage, put it all back together, and now I have a working hinge again!
    DIY Senior Member TedL's Avatar
    Sep 2006
    NY Capital District
    As the owner of 5 Toto soft close seats, I'd really appreciate it if someone could identify the factory fluid , and a source for it if it's not a generic item like mineral oil.
    DIY Junior Member DECJ's Avatar
    Mar 2011
    La Sal, Utah
    Quote Originally Posted by TedL View Post
    I realize that this is an old thread, but I was having the same problem and contacted Toto tech support regarding what the factory uses for the fluid, and this was the response I got via email earlier today ...
    I’m sorry but I cannot suggest any type of fluids to use or ways to repair. We do not have any specs on what is used in the hinge, nor do we have ways of fixing. Your best bet is to do exactly what you’re doing by researching on the web. We do not manufacture the seats themselves.
    So, I will do the same as gerlando and substitute a material that approximates the same viscosity (and that I have available).
    DIY Junior Member Al Thumbs's Avatar
    Aug 2011
    MetroWest, Mass.
    Default It's not mineral oil
    I used Gerlando's excellent instructions to open up the hinge on my seat. I don't think it's mineral oil. It is clear, sticky, and thicker than mineral oil. It reminded me of Kayro corn syrup, but thicker still. I used grease to replace the liquid, but it did not work for me. Will try again.
    Mar 2011
    La Sal, Utah
    Quote Originally Posted by Al Thumbs View Post
    Let us know what material you come up with that works.
    Good luck!
    Don
    Engineer Furd's Avatar
    Jul 2007
    Wet side of Washington State
    I suspect the fluid is glycerine.
    Mar 2011
    La Sal, Utah
    So, is glycerine all that much more viscous than mineral oil?
    DIY Junior Member Greenegs's Avatar
    Sep 2011
    Oregon
    Yes, glycerine is very thick, and sticky. It is not a lubricant at all.
    I agree that the soft close mechanisms are probably filled with glycerine (clear, odorless, colorless, and sticky).
    On my Toto, only the lid soft close had failed. The seat soft close was still working; it just could not handle the extra weight of the lid.
    I didn't have any glycerine so, as a temporary 'fix', I swapped the lid and seat soft close mechanisms. The lid is used much more, so having the soft close on that is at least better than neither working.
    DIY Junior Member bighornram's Avatar
    Aug 2009
    New Mexico
    I'm having the same issue with my 2 year old seat. ToTo replied that it must be replaced and cannot be repaired. I'm off to try and find glycerin to refill the hinges. The substance looks like silicone caulk when you squeeze it out of the tube.
    Aug 2009
    New Mexico
    I got a bottle of 100% veg. glycerine and filled both hinges. It is not as thick as the original material. It didn't fix my seat. I am going to give it more thought but think that grease might be a better choice. Vaseline could be a good choice also.
    Aug 2009
    New Mexico
    I filled the hinges with vaseline and still is a regular slamming down in the night toilet seat now. This seat is barely 2 years old. IMHO the functionality should be longer than 2 years. We are a low use location also, is just my wife and myself. This seat probably wouldn't last a year with a household with more than 2 members using it. It is also pitiful that Toto doesn't offer the hinges which can be easily replaced. Sorry Toto but I hope your toilet doesn't disappoint like the seat did. I replaced both toilets in my home with them.
    I absolutely do NOT recommend purchasing this toilet seat.
    Mar 2011
    La Sal, Utah
    While I think the Toto toilet is a superior design, I too am quite disappointed with their lackluster customer support stance on the soft close toilet seat. We are in a similar situation where it is just my wife and I and we never forced the seat closed. It is just too short a time with a modicum of use that has led up to the failure. I just can't believe that no one in Toto knows what viscous fluid was originally used in the soft closure mechanism. I still hope to make something work, but I will NOT be buying a replacement that Toto will continue to not stand behind.
  1. Toto Drake soft close
    By HoneySuckle in forum Toilet Forum discussions
    Last Post: 02-06-2008, 10:38 AM
  2. Toto soft close seat
    By chaoster in forum Toilet Forum discussions
    Last Post: 10-05-2006, 11:18 AM
  3. TOTO ZOE Soft close toilet seat
    By jw1 in forum Toilet Forum discussions
    Last Post: 05-27-2006, 06:07 PM
  4. toto soft close, other options?
    By raygunclan in forum Toilet Forum discussions
    Last Post: 03-23-2005, 08:32 AM
  5. toto soft close, other options?
    Last Post: 03-13-2005, 07:17 PM
