Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Problem with new well, output pressure drops off
    DIY Member ron in sc's Avatar
    Mar 2005
    South Carolina
    Question Problem with new well, output pressure drops off
    New well, 20' deep, plenty of water.
    Pump will prime and run but it will drop down to about 5 psi or less and then pump back up slowly but only to 20 psi at most.
    If I stop outlet water the pump will pump back up and then shut off as it should.
    What might be going on?
    DIY Junior Member masterpumpman's Avatar
    Mar 2007
    Virginia Beach, VA
    Default Limited Water
    You have a limited water supplying your pump.
    Mar 2005
    South Carolina
    Could I be to deep? I have water in the hole that I we put the well point down in. It's about 5" in diameter and has water that's pretty clear all the way up to about 4' from the top of the hole.
    The well is about 10' from the marsh behind my house.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Is this a pounded-in point? Have you developed the flow on the point yet?
    Mar 2005
    South Carolina
    It's the kind of point you run down with it connected to a hose.
    I'm not sure I know what you mean you by have I developed the flow on the point yet?
    Mar 2007
    Metro NYC
    The screen on a well point can be clogged with particles, and forcing water back and forth through the screen can increase the open area for water to flow in. Most well points in my neck of the woods are steel, with screens that occasionally need to be cleared of particles. Most of these points were pounded into the ground with slide hammers. At the beginning of their life, these points needed 'developing' - to clear the inlet screen.
    Previous member sammyhydro11's Avatar
    Dec 2006
    Massachusetts
    Sounds like you have a dug well with a foot valve on the end of your dop pipe. What is the make and model of your pump and what kind of fittings were used to plumb it together?
    SAM
    Mar 2005
    South Carolina
    Quote Originally Posted by sammyhydro11
    Sounds like you have a dug well with a foot valve on the end of your dop pipe. What is the make and model of your pump and what kind of fittings were used to plumb it together?SAM
    I have one of those 1 1/4" PVC well points. All connections are glued. All pipe is 1 1/4"
    Pump is Myers 3/4 hp. Model #HJ75S, attached to a Wellsaver tank model #LPT7H.
    Unpluged tank last night and it held pressure, so no leaks.
    Edited:
    Is it possible I went to deep, 20'? I went that deep because my original well went dry after 23 years. It was located elsewhere on the property and not near the wetlands behind the house.
    Dec 2006
    Massachusetts
    Ok so you have a 5" well with a 1 1/4" foot valve in the well.I read it right this time! Is there a screen on the end of that well casing? Who installed the well and what does it produce for water?If you know what it produces for water we can rule out the well as being teh issue. Just because you see water in the well doesn't mean that it will keep up with your demand. I'm thinking that you could have a vacume leak somewhere or there is a restriction in the suction line. With a well that size in diameter a submersible pump would be perfect.
    SAM
    Mar 2005
    South Carolina
    Sam,
    Itís only 5" wide for the first 5'. I have no casing. The 1 1/4" pvc goes down with the well point that has tiny slits in it, the part with the tiny slits is 4' long.
    There is no well casing.
    Me. I did the same procedure 22 years ago for my other well. Water that it does produce is clear. Volume wise it will build pressure, but then after that is released it kind or gurgles water up at very, very low pressure.
    Dec 2006
    Massachusetts
    Ok,so how did you get the 1 1/4" pvc well down to 20'? What was the slot or mesh size of the well screen?
    SAM
    Mar 2005
    South Carolina
    Slit size is 10,000th.
    Well point has holes on the end to I pushed it down. I used a sand shark on a 1 1/4 pvc pipe next to it to loosen up the sand to get it down. Worked well that's why I think maybe I'm to deep.
    I pulled well point up to aobut 16' and it's pumping better now, but if I open outlet all the way pump will loose pressure and stop pumping water.
    Previous member
    Jul 2005
    Riverview, Fl.
    How did you determine you have plenty of water?
    Mar 2005
    South Carolina
    Quote Originally Posted by speedbump
    It sure appears I'm wrong with that theory. I thought with water filling hole to 5' from the top there was plenty.
    Previous member
    Jul 2005
    Riverview, Fl.
    The best way to tell is with a Pitcher Pump. Use it every five feet.
    bob...
