Ok, I posted a question about my home last week and now the boss wants me to help at work.
Our building is on a well and one of the six pressure tanks has gone bad. (A 96 gal tank that is rusty and leaks) I drained it and it reads 0 psi. (It's one of two State 96gal tanks, 2 Wellxtroll wall mount tanks each measuring about 2 ½ ft in length and two unknown size tanks in the ceiling). Why in the ceiling I don’t know. The original plans only called for two 96 gal tanks and it is my thought that someone in the past has added the other tanks because the 96 gal tank went bad and they were too lazy to remove it.
I’ve looked in our invoices and see that we discharge into the city sewer about 14000 to 19000 gal per month or 600 gal per day. We have a large storage tank I could park my truck in with two 3hp pumps that feed the building. From what I’m told each pump will alternate usage so as to not wear one out. Each one has an hour meter I could use to see how much they run. My pressure switch says it’s a 30-50 but it reads anywhere from 70 to 75 all the time. Need a new one of these too. I drained the entire 96 gal pressure tank before the pump turned on. If I understand how this system works, the well pump fills the large storage tank and the other two pumps pressurize the building. I would think the storage tank would have floats to turn the pump on and off and would be far enough apart to keep the pump from turning on and off all the time. I don’t know what size the well pump is or how deep.
Here is my question: What would I need to do to figure out if this bad pressure tank is even needed anymore? Seems to me that if it takes close to a hundred gal to turn on one of the pressure pumps we may not need it?
