Results 1 to 8 of 8
Thread: Hard to remove fill valve
    Default Hard to remove fill valve
    Hi all,
    I'm a new homeowner and I need to replace my first fill valve. I can't get the old one off! The bolt at the bottom of the tank is completely stuck. I tried for two hours last night with no luck (well, I got the lower one off but the one that's in contact with the tank won't budge). Any ideas or tricks about removing it?
    Alex
    Default valve
    Unless it is a brass fill valve with a "pot metal" nut, it should not be that tight so you may be doing something wrong. If it is really that tight, you might want to call a plumber before you crack the tank and have to buy a new complete toilet.
    Good point. Maybe I'm using the wrong tool. The thing is plastic and I was trying to get it off with a wrench. The whole assembly turns when I try to loosen it.
    Plumber jimbo's Avatar
    You will have to hold the inside piece with your hand while applying the pliers to the underside nut. All else fails, very carefully hold a hacksaw blade inyour hand and cut the nut. On an all plastic set up, this should not be necassary. It will come loose.
    Engineer maddog's Avatar
    Aug 2006
    near San Jose, CA.
    I had the exact same problem removing a plastic fill valve. It would just spin around in the tank while turning the plastic nut on the bottom. I used a hack saw blade, which easily cut through the threaded part of the valve. I then carefully cut about half way through the plastic nut and was then able to pry/separate/split the nut with a thin blade screw driver. -dog
    Plumber plumber1's Avatar
    Aug 2005
    Florida
    Cut it off.......
    Default nut
    If it is plastic, heat a screwdriver with a torch and melt a groove up the side of it, then snap it off the thread. You won't have to worry about damaging the tank or anything else doing it this way.
    Talking It's FIXED
    Thanks for all the suggestions. I couldn't get anything to work.
    Then my dad came over and chiseled it off in 10 seconds!!
    I HIGHLY recommend that method!
