Hi,
My problem is that the Domusa oil boiler is placed in a garage under the house, where the temperature seems to be a few degrees warmer than inside the house. If the house is empty and the temperature in the garage drops to 5º C , then the bolier turns on *but* the temperature in the house may be a few degrees lower, so the pipes could freeze before the boiler turns on.
Is there a way to raise the minimum temperature of the anti freeze function, say to turn on at 8 º? Or is it possible to remove the anti freeze sensor from the boiler and place it in the coldest part of the house, obviously connected to the boiler?
Thank you.
