Digging down to your line is not likely to be helpful unless there is a cleanout fitting somewhere, and there likely is not one outside your house.Originally Posted by Duphus
I would doubt the previous owner did the connection himself or herself, and I would be very surprised if that old septic tank is still any part of your system.Originally Posted by Duphus
Have you actually opened that tank to see what is inside and/or possibly going on there? Septic tanks are always "full", but poorly-working tanks can build a hard crust of scum that can eventually block either the inlet or outlet, and septic tanks can eventually collect quite a layer of sediment at their bottoms. Since you have already done some digging, dig a little more in that area and see whether you can find an access to that tank. There will likely be two of them, with one at each end. My suspicion, however, is that the top of that tank has been broken down and a new pipe was laid over it to bypass it altogether when your house was connected to the city sewer those many years ago. And if so, whatever clog you have might simply be out-of-reach for a 50' snake.Originally Posted by Duphus
