Testing PVC Pipes Under Concrete Slab
Fran
Could someone please tell me who oversees the plumbing contractor to make sure that Foam Core PVC is not used under a concrete slab? Are there any inspectors involved who check the accuracy of the plumbing work? In a previous message I was told that Charlotte Schedule 40 Foam Core PVC is fine to use in a new custom house, but it is not to be used under the concrete slab. There is Foam Core sticking up from the concrete slab. What do we do next?
Gary Swart
Yakima, WA
You should contact your local building inspector and have him check it out. You should also check your contract and verify with the inspector and contractor that the materials used are up to code and are what were specified in the contract. Do this now before more work is done that might have to be undone to met code/contract, and certainly before you accept the house.
pvc
The inspector verifies that the material used is the minimum required by the code. The contractor would be responsible for anything better than the minimum if it is specified in the contract. If that "upgrade" is not furnished then the question would be who accepted the upgrade. If it was the general contractor, but the plumber's contract specified "to code", then the general is responsible. If the plumber specified Sch40 and did not install it, then he is responsible and should either replace it or give a "substantial" rebate as "punishment" for deviating from his agreement.
