Results 1 to 9 of 9
Thread: Removing Stripped Faucet Seat
    DIY Senior Member bbillcee's Avatar
    Feb 2007
    NY
    Default Removing Stripped Faucet Seat
    ancient faucet that has a bad seat......tried getting it out with the proper tool and stripped it!
    this is in a tub body behind the wall....any trick to get this seat out?!
    the temp fixed i used for now was a beveled washer instead of flat.
    i would also try an easy out but i have to see if its long enough to get back in there
    Plumber Cass's Avatar
    Whaat tool did you use to get it out?
    Feb 2007
    NY
    a seat tool.....one side square and the other like a pentagon shape
    i'm going to buy a nipple extractor and see how that works out
    Which tool?
    They have one that is shaped like an L and another that works with a ratchet.
    What brand is the faucet?
    Feb 2007
    NY
    its an L shape......also its a gerber faucet
    If you can find the other type of tool and the hole is not perfectly round, or even if it is, you may be able to bang in the removal tool tight enough to get it to work. I don't think you will find a nipple extractor small enough to fit in the seat hole.
    The L type extractors are junk in my NSHO. But a lot of people use them.
    Go to the big, online, auction site and look up this item in the buy box.
    160086458861
    Feb 2007
    NY
    yes that looks very good.....i will stop by the plumbing supply and see if they have something like that
    thanx
    If the seats are round you may be able to bang in the removal tool and get it to score the seat enough so you can see the marks then if you can find a small and sharp angled file, file some corners into the seat for the tool to grab. Be carefull.
    Default seat
    Be careful when you "bang" the removal tool, because many of those tools are too long and hit the back of the faucet. If you bang them, you will punch a hole in the back of the faucet, and then removing the seat will be a moot point because you will have to replace the entire faucet.
