Results 1 to 5 of 5
Thread: Small Water Main Valve leak, need help!
    Default Is this an old globe valve?
    I am remodeling the bathroom and when i went to turn the water off and on a couple times the old main valve sprung a small leak, I'm pretty sure its coming out where the top arrow is but it could be the bottom one. I've done some research and this looks like an old globe valve. So my question is, should I just take the valve part off and repack it and get a new one or should I just replace it with a ball valve. I have posted links to pics below, just copy and paste them into your browser. Thanks.
    http://i60.photobucket.com/albums/h3...e/100_0544.jpg
    http://i60.photobucket.com/albums/h3...e/100_0546.jpg
    Plumbing Contractor TNPlumber's Avatar
    Aug 2006
    East Tennessee
    Default Ball Valve
    If you have the skills then definately go with a ball valve. You could repair what's there but, it looks like a fairly straight forward job.
    Scott
    "Nothing that time and money can't fix."
    Scott
    Plumber Cass's Avatar
    Be for you replace it try just loosening the nut then re tightening it and it may stop.
    Default leak
    Just tighten the nut a bit. The leak should stop.
    I see it that way too. Looks like there is still a lot of old packing under that nut.
