Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: MIXET shower valves
    DIY Junior Member Landlord's Avatar
    Mar 2007
    California
    Default MIXET shower valves
    I am a landlord, and I have MIXET single handle shower fixtures in my apartments (Cartridge # MS-5AT).
    I recently replaced the cartridge in one shower about a month ago because the fixture produced only cold water. The tenant now complains that the shower again produces only cold water and that the new cartridge only worked for about 5 days.
    Any ideas what to do? I can replace the cartridge again, of course, but I would like to solve the problem.
    Thanks for your help.
    Default Mixet
    The only way that could be a factor would be if the valve body was so badly worn that the cartridge could not seal the inlet ports, which is not likely. You probably have a different problem but we cannot diagnose it without being there. There is an online source for a Moen style cartridge that cures the common Mixet problems.
    Nomix Inc. repair cartridges that fit Mixet brand valves
    It is a Moen style stem to replace the Mickey Mouse one that Mixet uses.
    Mar 2007
    California
    Default MIXET cartridge
    HJ, thanks for your advice.
    Do you recall the URL of the site that refers to a MOEN cartridge that is supposed to cure MIXET cartridge problems?
    If not, do you remember any keywords that I can search on?
    Plumbing co. harron manos's Avatar
    Oct 2009
    lake dallas, tx.
    Quote Originally Posted by Landlord View Post
    go to this web site to solve your problem it is guaranteed !
    www.nomix.com
    DIY Member Phillbo's Avatar
    Nov 2008
    Arizona
    Default Help Identify Shower Valve
    Hi all,
    Can you assist me in identifying this shower valve. Is it a cartridge type ? I'm replacing all the hardware in the tub/shower and hope to not have to pull it apart to identify the replacement parts.
    Any help is greatly appreciated !!
    Name:  shower valve 1.jpg
Size:  24.3 KBName:  shower valve 2.jpg
    Nov 2008
    Arizona
    OK.. not sure why my thread was moved into this one... Is someone trying to tell me I need a nomix cartridge too ?
    If you wanted fast answers, this was the best way. It tells you it's a Mixet valve, and with Mixet, the best replacement is the Nomix cartridge.
    You can repair with the Mixet cartridge too, but at least now you know your options.
    Nov 2008
    Arizona
    Cool, thanks for the help... Anyway of telling buy the pics which NoMix Cartridge Model i would need to order? Also , any special tools needed to remove and install the cartridge?
    I don't have a problem with the hot cold blend, it just does not shut off all the way sometimes.
    hj normally checks these things in the AM
    By tomorrow you should know.
    Nov 2008
    Arizona
    Thank you for providing such a wonderful resource!
    mixet has 3 baisc cartridge types: NEW....post 1968, or OLD, pre 1968. There is also an extended cartridge where guts are the shorter NEW style, but the outer end is extended in case you tiled a wall or otherwise ended up short.
    You can still get these, as well as the nomix, and the handles. But mixet was never much good, you will not be able to change the style of handles ( although some other color are around) so at some point, you need to consider changing the valve. Especially with the price of the nomix products. If you are giving any consideration to a major bathroom remodel, this situation should influence your decision.
    Nov 2008
    Arizona
    I want to replace the valve/handle .. are you saying I can't replace with a different brand / model ? Don't knew faucets come with a new cartridge that fits the valve?
    Mixit Ultimate Trim
    Unfortunately you have a very misguided understanding of the situation. The valve body which is inside the walls...soldered to the pipes.....is a very specific brand and model. In this case, MIXET. The ONLY thing which goes with any valve are EXACTLY the brand and model that is there. THAT is why you can't do anything except REPAIR a shower valve. When it is relatively NEW, and the COMPANY is still in business, there are often options for different trim styles and colors which will work with that particular valve and stem. Since MIXET is LONG GONE, you are left with what the aftermarket companies make available to you, which is limited. Then to boot, mixet had that inherent design defect where the valve body wears, and you will have cross over and hence need the very pricey nomix stem.
    From the exterior, you cannot tell the difference between the short and long stems. Once you remove the handle and chrome ring you will be able to see if there is an "adapter sleeve" between the cartridge and the valve body. IF there is, or the temperature handle only rotates 180 degrees, you have to remove a "half moon shaped" clip from the side of the valve before you try to pull the stem out. If your part number is correct, then you need the standard short stem.
