Results 1 to 15 of 18
Thread: MIXET shower valves
Hybrid View
    DIY Junior Member Landlord's Avatar
    Mar 2007
    California
    Default MIXET shower valves
    I am a landlord, and I have MIXET single handle shower fixtures in my apartments (Cartridge # MS-5AT).
    I recently replaced the cartridge in one shower about a month ago because the fixture produced only cold water. The tenant now complains that the shower again produces only cold water and that the new cartridge only worked for about 5 days.
    Any ideas what to do? I can replace the cartridge again, of course, but I would like to solve the problem.
    Thanks for your help.
    Default Mixet
    The only way that could be a factor would be if the valve body was so badly worn that the cartridge could not seal the inlet ports, which is not likely. You probably have a different problem but we cannot diagnose it without being there. There is an online source for a Moen style cartridge that cures the common Mixet problems.
    Nomix Inc. repair cartridges that fit Mixet brand valves
    It is a Moen style stem to replace the Mickey Mouse one that Mixet uses.
    Mar 2007
    California
    Default MIXET cartridge
    HJ, thanks for your advice.
    Do you recall the URL of the site that refers to a MOEN cartridge that is supposed to cure MIXET cartridge problems?
    If not, do you remember any keywords that I can search on?
    Plumbing co. harron manos's Avatar
    Oct 2009
    lake dallas, tx.
    Quote Originally Posted by Landlord View Post
    go to this web site to solve your problem it is guaranteed !
    www.nomix.com
    DIY Member Phillbo's Avatar
    Nov 2008
    Arizona
    Default Help Identify Shower Valve
    Hi all,
    Can you assist me in identifying this shower valve. Is it a cartridge type ? I'm replacing all the hardware in the tub/shower and hope to not have to pull it apart to identify the replacement parts.
    Any help is greatly appreciated !!
    Name:  shower valve 1.jpg
Size:  24.3 KBName:  shower valve 2.jpg
    Nov 2008
    Arizona
    OK.. not sure why my thread was moved into this one... Is someone trying to tell me I need a nomix cartridge too ?
    If you wanted fast answers, this was the best way. It tells you it's a Mixet valve, and with Mixet, the best replacement is the Nomix cartridge.
    You can repair with the Mixet cartridge too, but at least now you know your options.
    Nov 2008
    Arizona
    Cool, thanks for the help... Anyway of telling buy the pics which NoMix Cartridge Model i would need to order? Also , any special tools needed to remove and install the cartridge?
    I don't have a problem with the hot cold blend, it just does not shut off all the way sometimes.
    hj normally checks these things in the AM
    By tomorrow you should know.
    DIY Junior Member Dave pederson's Avatar
    May 2013
    Oregon
    The issue your are having with the mixet valve is most likley not the cartaige that is the problem. Its the pressure balancing spendle that cuases this problem. The spendle is either corroded and stuck or it is missing. It is located in the nut to the right of the main stem near the screwdriver shut off on the cold side. Use a stait screw driver to lossen the cap and pull it out to inspect it. It is A stainless sleave with o rings on the out side and a stainless spendle on the inside. The inside spendle must be able to move freely. If it cant it will only let cold water or hot water through. Soak it in oil or wd40 to free it up.
  1. Tired of Mixet shower handles
    By sdcabob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-25-2009, 06:32 PM
  2. mixet shower valve
    By ldf in forum Shower & bathtub Forum & Blog
    Last Post: 04-27-2008, 03:28 PM
  3. Mixet Shower Faucet
    By smokeybear in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2007, 05:11 AM
  4. Old Mixet shower valve
    By David here in forum Shower & bathtub Forum & Blog
    Last Post: 12-19-2007, 11:00 PM
  5. Mixet shower cartridge
    By AnotherHomeOwner in forum Shower & bathtub Forum & Blog
    Last Post: 07-05-2006, 08:28 AM
