Results 1 to 5 of 5
Thread: removing Grohe cartridge
    Default removing Grohe cartridge
    Is there a trick to removing the cartridge from the Grohe tub filler valve and diverter? Need to remove the cartridge before sweating, but can't get it out. Thanks.
    I've only removed a faucet cartridge, but assuming it is similar, there was a metal ring at the top with two screws. Just remove the two screws and the whole thing pulled straight out. You may find it helpful if you look at the parts blowup diagram. If you didn't get one with the valve (or lost it), then they are available on-line on the www.grohe.com site.
    DIY Junior Member ratanshah's Avatar
    Feb 2010
    Jeannette, PA
    Default Remove
    It is not easy but possible
    Once you succesfully unscrew the cartridge you will have to wiggle it loose with pair of plyers
    If too hard to unscrew use any home depot or lowes product for loosening
    ratan
    ratanshah@comcast.net
    Dec 2007
    Quote Originally Posted by ratanshah View Post
    Should I use the Estwing Hammer I bought at Lowes or, the Pick Axe I bought at Home Depot?
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    This is a difficult task, and grohe doesn't provide you with the proper tools to do it. You will have to carefully use a vise to hold each unit while you try to work on them. You can use sockets on each of the handle cartridges, but you'll need a special deep socket to work on the diverter stem. Good luck with this one...you'll be cursing grohe after this install.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
