Removing Moen tub drain
hercules
I'd like to remove the Moen Lift n' drain stopper in my bath tub to clean the drain. However, I cant figure out how to remove the Push-N-Lock drain. Can't find anything other than drawings on the Moen site.
Moen part number 101654. Any ideas?
Refinisher
Call the tech support of Moen, they will be able to walk you through it.
cbl
Does it have the "pull knob" on top? In the up position hold the stopper then unscrew the pull knob. There should be a square hole under the knob. Use a big screwdriver in the hole and unscrew the assemble from the drain.
