R
rickteresa
Guest
I have a Well/Trol by Amtrol pressure tank. Not knowing much(if anything) about pressure tanks, when the pump runs and fills the tank with water, then the pump stops and the pressure guage now reads 40psi(from 20psi), I assume the pump now stops. As pressure reading goes down back to 20psi I assume the tank should go down to empty correct? Then the pump kicks in at 20psi again to refill? All this is about the pressure tank. I don't think the tank is emptying. It seems to still be full of water at any pressure reading. The pressure is fine in the tank. Am I correct in any of these assumptions?
