Results 1 to 2 of 2
Thread: slow bathtub drain
    Default slow bathtub drain
    Water from my whirlpool bath tub drains slowly -- probably due to hair/bath crystals. I've got a twist-and-pull drain plug that is not meant to be removed. The drainpipes are not accessible either.
    What is the best way to free the clog? Can I remove the overflow and use a snake? Are there any commercial products that will clear it (drain-care)?
    DIY Senior Member e-plumber's Avatar
    New York
    Default Slow Draining Bathtub
    By using a power drain cleaner to break up and hopefully remove the restriction.
    Yes. That is the way it's done, the overflow piping leads straight to the drain trap for easier cable access.
    No.
    e-plumber
