Page 18 of 24 FirstFirst ... 89101112131415161718192021222324 LastLast
Results 256 to 270 of 358
Thread: American Standard Cadet 3 Three Toilet consumer product review
  1. #256
    Apr 2005
    Installed a Cadet 3 today. I never try to crank down the tanks till they bottom out to the sanitary bar. I tighten down enough for a firm connection and no leaks, nothing more. I've been telling customers how to get those flappers without costing them money.
    Seems I've replaced a lot of toilets lately.
  2. #257
    DIY Senior Member vtxdude's Avatar
    Nov 2009
    NH
    I also just replaced my 2 toilets with Cadet 3's. I had someone who was a plumber years ago install them for me. One thing I noticed is that the top of the tanks were loose...you could rock them a bit back and forth. I stumbled upon this thread and have picked up a few tips...
    I got out my deep socket 13mm ratchet and started to tightened a bit as they were sort of loose I had the level on there and tightened them down pretty good Used a level and horizontal wise it is dead on that way but front to back it is tilting forward ever so slightly so says the level...is this ok?
  3. #258
    Nov 2009
    NH
    Oh let me add one other thing and have no idea if this means anything....I tightened down as I mentioned above so that there is just a tiny little bit of space between the tank and the bowl in front and looks almost the same on the back.....so it looks very similar to the picture about 5 replies up...although as I said it slopes forward a bit(with the level I see no way I could raise the front of it to match the back, it seems too much)
    Anyways being the curious one on who things work I wanted to see how this gasket seals and did not know that the inner seal is under the flapper...So I took a peek and I see that the black ring on the "inside" of the drain is not uniform all the way around..it is squished in in some spots and uniform in others..I take it that is from me tightening the tank down
    Now is this ok as it compresses down as you make it tight or am I just being really weird noticing this. I just don't want to have a floor full of water one day.....but I figure if people are tightening them down to where the bowl just about makes contact with the tank they should have a similar result?
    Just trying to learn from you guys who know this stuff in and out
    Thank you
  4. #259
    DIY Member
    Sep 2006
    Mexico
    I have been following this thread as we are in the market for a new toilet. I guess I am way behind when it comes to the world of toilets. I have lived in homes where the toilet was 20 years old and other than replacing the float system with a Fluidmaster the toilet worked well. I also have a pubic toilet at my business that is used by truck drivers. It is about 15 years old and is a cheap made in Columbia toilet. Works fine. Now you need to be an engineer to get a good toilet. We winter in Mexico and need a new toilet to replace a Mansfield that I hate. I ws considering the Cadet as we have a Cadet 1.6 that is 15 years old in our simmer cottage. Works great. I think I paid about $160 which was a little pricey 15 years ago. After reading this thread I think I will pass on the Cadet. We are 300 miles from an American home depot and I do not want to puchase something that likely will be faulty. The plumbing supply stores in Mexico and Home Depot Mexico sell a lot of those new dual flush toilets. They scare me. Too many things to go wrong and parts not readily available. We do not have a water meter so saving water is not really important. I do see some American Standard toilets but have not checked to see where they were built. A lot of the expensive toilets here are manufactured in other Latin American countries. Our water is quite good right now but once the town well gets a little older the quality will deteriorate and become very salty. Hard on toilets. Question : Is there a 1.6 toilet that will flush well and use standard components?
    Moisheh
  5. #260
    DIY Member Alan Muller's Avatar
    Oct 2009
    Delaware
    I just installed a Cadet 3 1.28 gpf: 3378.128.020. Listed as a flo-wise in the MAP report but not on the box. It has a normal flapper not the raised flapper Champion-type I was expecting from Am. Std. literature.
    It flushes OK, surprising considering the very low head available. The flapper action isn't entirely consistent, leading to some variations in flush and bowl fill. Maybe I need to fiddle with the chain as others have mentioned?
    Better, I think to buy the bowl and tank separately. Big box is hard to manage. Cheesy steel hold-down bolts I didn't use. Wax ring with plastic nozzle in it and I don't use those. Seat is no more than usable.
    Overall: OK, or a bit more than OK for the price, but not a Toto.
    am
  6. #261
    DIY Junior Member davefoc's Avatar
    Nov 2006
    California
    Quote Originally Posted by Alan Muller View Post
    am
    Thanks for the info.
    I agree about the seat and have generally replaced the cheesy plastic seat they come with, although I have usually bought the tank and bowl separately so I haven't had to deal with the seat. However, I have installed at least one with the cheesy plastic seat (CPC) and I'd have to say that if you don't mind a CPC they hold up pretty well. The various wooden seats that I've installed in my apartment building over the years haven't held up all that well. My current standard is a $20 wood one with nickel hardware that I buy from Lowes and I don't think those last as well as the CPC's. and do I get even one more dollar of rent money on my apartments because I haven't been installing CPC's? I doubt it. Maybe the CPC's aren't so bad.
    As to the throw away the wax ring because it has the plastic nozzle:
    I think I've heard this before on this forum. I have always bought the ones with the plastic nozzles. Maybe I shouldn't? What's the issue?
  7. #262
    Oct 2009
    Delaware
    Quote Originally Posted by davefoc View Post
    I used to use them too, then thought about it and wondered "why put in a nozzle smaller than either the bowl outlet or the line it feeds into? What can be the benefit of creating that obstruction?" (Just measured the ring that came with the Cadet: nozzle outlet is about 2-9/19". Measured a Harvey's at about 2-5/8".)
    I'm not a plumber and don't set toilets that often. I try to measure each job and usually there is about 1/4" for wax, and the horn of the bowl sticks down into the flange. So the wax is only a gas seal unless the line is plugged and backing up.
    I can see there might be a use for the plastic nozzle in case of a depressed flange or bowl with a broken horn or.....
  8. #263
    If the ring is not centered properly in the flange, the whole funnel can collapse and block things off. Also, if the flange height isn't where it should be, that little extra thickness of the plastic can allow a leak path if it gets warped.
  9. #264
    Default Cadet 3 flapper comes off
    Folks -
    I have a Cadet 3 10" rough-in toilet. Got it during a remodeling project bad dream (thus no desire for warranty work) a couple of years ago. Eventually it got installed into a spot that could have taken a 12" rough-in, but....
    Anyway - from day 1, it runs because that flap ears pop the tube every time it's flushed. We've adjusted the chain to every possible position. Got American Standard to send me a new one. I've read the reviews on here - seemingly very positive - but as far as I am concerned this thing is poorly designed. I am not a plumber, but I am pretty handy - but this thing has me stumped and my wife has explained - correctly - that she has had enough.
    Sugggestions? I do not WANT to spend the money on a new toilet, but if that's what it takes - so be it.
    Thanks to all in advance!
    Steve
  10. #265
    Engineer maddog's Avatar
    Aug 2006
    near San Jose, CA.
    Look for the Korky replacement flapper for the Cadet 3 - you should be able to find it a big-box store or Ace HW. They seem to work better than the ones from American Standard.
  11. #266
    Health care analyst. dmtrunner's Avatar
    Dec 2009
    Saint George Utah
    Default Cadet 3 Tank Salesperson says slight rock is normal is that right?
    More than one sales person told me there is slight rock built into the Cadet 3 tank attachment system to keep it from breaking if a person leans back against the tank. They say this avoids breaking it. All toilets in my homes up to now are rigid and fit very snug to the bowl.
    After installation by a professional installer, there is slight rock on both of the Cadet 3 toilets. I don't know what to expect. What is the standard? Does anyone know.
  12. #267
    You might want to peel the paper wrapper off of the toilet supply.
    I think you will have to live with the large gap between bowl and tank.
  13. #268
    Dec 2009
    Saint George Utah
    Unhappy American Standard Cadet 3 Quality - buyer be aware
    I bought two Cadet 3 toilets based on recommendations from sales people and did compare it to a Toto. I felt this was the right toilet not based on price but on a cleaner bowl.
    Both toilets had defects. One had a small portion where it was brown on the bowl, I guess it was not glazed properly the second had a broken tank top. I have read similar stories about poor quality control. If I buy any more toilets I plan to visually inspect them before I take them home.
  14. #269
    Aug 2009
    Midwest
    Why can't they simply make an appropriate tank to bowl gasket for this toilet? Rock or lean of the tank is unacceptable and earns a "FAIL" rather than a "fantastic toilet" rating.
    You gotta wonder about an outfit that can figure out a 10 cent solution.
  15. #270
    Aug 2009
    Midwest
    Quote Originally Posted by Ian Gills View Post
    Hmmmmm. So there's no tank rock on Totos either?
    I doubt that.
    Not on my three Drakes. (I just checked them all for you, mate. ) When a tank is installed with a proper thickness gasket and makes three point contact with the porcelain it shouldn't be able to rock--porcelain is not appreciably compressible. Rocking is an indication of a defective or improperly installed tank.
    A little tank movement is normal for most toilets, except one-piece of course.
    I doubt that it is normal for a properly built and installed tank.
    Tank movement of a one-piece would indeed be bad...has American Standard managed that trick yet?
  1. Problem with the Flapper on American Standard Cadet 3, 4027.016 toilet
    By John Milich in forum Toilet Forum discussions
    Last Post: 05-07-2012, 05:10 PM
  2. American Standard Cadet 3 Toilet Flush Problem
    By Retired2006 in forum Plumbing Forum Discussion & Blog
    Last Post: 10-17-2011, 10:21 AM
  3. Replies: 12
    Last Post: 10-02-2011, 11:08 PM
  4. Replies: 25
    Last Post: 12-12-2009, 09:47 AM
  5. American Standard Cadet Flowise Toilet -- any good?
    By BettyG in forum Toilet Forum discussions
    Last Post: 09-05-2009, 04:28 PM
