Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Cast Iron drain + short brass stub = headache -- illustrated!
    DIY Junior Member ninotchka's Avatar
    Apr 2006
    Baltimore, MD
    Default Cast Iron drain + short brass stub = headache -- illustrated!
    Hi everyone! I'd be very glad for some opinions of a plan I'm considering.
    In my bathroom, I have a cast iron soil pipe and hub (2" i think) with a 1 1/4" chrome/brass pipe attached. I think it's leaded.
    Anyway, some demolition-happy moron* cut the brass pipe off so the stub out is only 1". Naturally, that's not long enough to attach a new trap to. It pretty much looks like this:
    What would you do? Theoretically, I could try and remove the lead from the joint and lead in a new pipe, but if there's any way to avoid that it'd be great. I'm not crazy about the idea of using a Fernco, since the fitting would protrude from the wall by about two inches and look really cheesy.
    One idea I had was to slip a chrome pipe w/hub over the existing stub, firmly packed with marine epoxy (or a product like this )and possibly wrapped with that fiberglass leak-stop tape (see below)
    Is this a real bad idea? If so, does anyone have any ideas that don't involve trying to get that pipe stub out?
    Thanks very much for any thoughts.
    *me.
    Drill out and remove the existing fitting and lead. Clean up the insides, then use a Fernco donut to install the pipe. The donut takes the place of the oakum and lead, so it doesn't stick out or show any more than the lead does now.
    DIY Senior Member TedL's Avatar
    Sep 2006
    NY Capital District
    Clean out the hub, put a Fernco donut in (I believe this is the part #22U-139 2X1 1/2 SW/CI HUB X PLASTIC) and come out with 1.5 inch 40 pvc that you can put a Marvel fitting on, your choice of 1.25 or 1.5.to receive the drain line.
    Default fitting
    It should be a tailpiece soldered into a threaded solder bushing. You can use a thin screwdriver and hammer to separate the chrome from the brass, (and pull it out). Then cut two slots in the brass about a 1/4" apart. Remove the small piece and then the brass will be able to be "folded" inward to loosen it and spin it out.
    Apr 2006
    Baltimore, MD
    I take it, then, that no one has any ideas that don't involve removing the currently leaded-in pipe? Because I'll tell ya, that thing looks like it ain't gonna go without a fight. Whoever put that in did not skimp on the lead.
    HJ, thanks for saying the magic words "solder bushing" -- I cleaned up the connection with some steel wool and now I can clearly see that you're right, the chrome pipe is soldered into another fitting. So the thing to do is to cut a chunk out of the brass fitting with what, a hacksaw blade? There's some junk between the brass and CI, but I'm hoping it's just light corrosion.
    Ted, does a "Marvel fitting" go by another name? I'm not sure what to look for there.
    Jim, yes, a donut would look much better than the band coupling I was using a temporary repair.
    I guess I'll see what happens when I get the bushing out, and if the interior of the CI fitting is threaded or not. Or should I use the donut regardless?
    Thanks very much for the time & info, everyone!
    Feb 2005
    Talking wipe the joint
    if it is a brass nipple coming out of the 2 inch cast
    all you have to do is get a propane torch and heat the
    brass nipple enough to get the lead residue off of it...
    wipe it clean with a rag.....
    then all you got to do is get a 2 inch FERNCO fitting
    or a 2 inch NO HUB clamp and attach on to that brass
    nipple
    .......and you are good to go cause that brass insert is
    good for another 100 years..
    Apr 2006
    Baltimore, MD
    Quote Originally Posted by master plumber mark
    Nope, it's a chrome/brass tailpiece soldered into a brass bushing. I hope I'm going to be able to cut it out gracefully.
    Default bushing
    First get the chrome piece out by cutting it out, or heating the solder until the joint comes loose.
    Sep 2006
    NY Capital District
    Sorry!
    A Marvel fitting adapts plastic pipe (sch 40, like is in the walls) to receive tubular pipe, like is under sinks. It solvent welds onto the outside of plastic pipe and has a threaded compression at the other end.
    The pic at the top of the first page here shows one at the wall end of the item.
    http://www.jb-products.com/pdfs/plastic_02-9.pdf
    Apr 2006
    Baltimore, MD
    Default Well, I'm making progress! I think.
    For those following my exciting saga...
    This is where I am right now:
    I nicked one of the CI thread, but only a teeny bit.
    Sadly, though, the whole thing is not collapsing and spinning out the way I hoped it would. In fact, it's not moving at ALL! Anyone got any tricks?
    Also, my local independent-plumbing-shop-guy recommended (and sold me) a brass Desanco instead of the donut. Ted, I think it's a brass version of your Marvel fitting..? I liked the looks because it doesn't look like it would require the brute strength of the donut to get right. On the other hand, the non-threaded part that goes to the tubing is a slip fitting and I am a little queasy about having that behind a wall. But it's not like there will be a lot of pressure on it... What's everyone's opinion on the Desanco?
    Thanks a ton for all the help!
    Can't tell for sure...is there enough room to just unscrew that elbow? If you can't get that out (I'm sure there is a way, one of the pros will tell from the picture), I'd just consider cutting off the elbow, then rebuilding it with pvc.
    Apr 2006
    Baltimore, MD
    Quote Originally Posted by jadnashua
    Eeeek. No, there's not enough room. And I spent so much time cutting those slots that damned if I'm going to remove the whole elbow now.
    If worst comes to worst I can cut it out chunk by chunk... but I really hope that's not what I have to do.
    I think you may need to cut a couple more hunk out like the one you have already done. Then the pieces will come out without too much effort other than maybe tapping with cold chisel or screwdriver to get them started. Once that piece is out, you can get a PVC threaded male adapter to screw in to the elbow and you're on your way.
    Apr 2006
    Baltimore, MD
    Quote Originally Posted by Gary Swart
    Me and the hacksaw will get back to work tomorrow I guess!
    Is there a reason to use the PVC adapter and not the brass? I would like to use a chrome/brass pipe coming out, because it's for a wall-hung sink and will be exposed.
    Me, I'd hacksaw that elbow right off of there and attach whatever I wanted. But, continuing what you are doing should be okay, too.
    I had to remove a cast iron fitting over Christmas. It took forever since I didn't have much room to work. Looking back at it, it would have been much easier and quicker to tear up the ceiling, have reasonably easy access, replace the fitting, then fix the ceiling. I'm pretty sure it would have been much quicker.
