TedL
My question is whether there's any reason to go to the trouble of making room for an outside mount toilet flange, rather than using an inside mount. Either flange will be all steel/CI.
Background
I'm refurbishing a basement half bath, on slab, including replacing floor tile and the current mounting setup for the toilet.
Current toilet mounting consists of 4" CI with a thin steel flange mounted above it (not connected to the pipe) covered by a lead sleeve "top hat" that goes down into the pipe. The rusting flange is anchored with four rusting screws going into plastic anchors set into the concrete. Concrete touches pipe all around, so would require cutting back to make room for an outside mount flange.
I do plan to use lead anchors and stainless screws.
TIA.....
Background
TIA.....
