Results 1 to 2 of 2
Thread: 2 wire vs 3 wire thermostat
    DIY Junior Member d_butka's Avatar
    Oct 2004
    Default 2 wire vs 3 wire thermostat
    I have Oil fired hot water baseboard heat, with 2 zones. I have wanted to install a programmable thermostat, but I cannot find one that works with 3 wire aquastat.
    What is the difference between 3 wire & 2wire thermostats?
    Is there a way for me to adapt a prog therm. for use in 3 wire system?
    Default t'stat
    It has been over 30 years since I worked on wet heat, but I do not ever remember needing a three wire thermostat for just heating purposes. Usually the aquastat has two terminals and the thermostat just switches them on or off.
